Getting the brushes out of a Bosch WFL2260
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Getting the brushes out of a Bosch WFL2260
  • #15011
    cleudo2006
    I’ve got the motor out of my Bosch with a view to replacing the brushes (drum won’t budge & open circuit measured across the brushes).
    Can anyone tell me how to actually get the things out? I’ve pushed, prodded, and pulled but can’t get them out of their housings.
    Theres a small plate covering the end of the spring (onto which the spade connector fits) and this can slide back and forward, but doesn’t come out.
    You don’t have to remove the housing do you?
    Any help gratefully received
    (& does anyone have a part no. for replacement?
    Thanks,
    Jim
    #161679
    cleudo2006
    Re: Getting the brushes out of a Bosch WFL2260
    Sorry, cancel that – just got it!
    you slide them over till the cutout matches up with the holder then it lifts up and out – just wasn’t pulling hard enough.
    JIm
    #161680
    gegsy
    cleudo2006 wrote:Sorry, cancel that – just got it!
    JIm
    Its the getting them back in thats the hard bit 😉 make sure you get the brushes facing the correct angle on the commutator. Best way to check is to offer the brush down the guide until it meets the commutator.Spin the motor shaft by hand, if no horrible clipping noise is heard then it is in the correct orientation.
    Dav1dM
    Please forgive me for “piggy-backing” on this topic, but I have a related question I’d be grateful for help with. I’ve mamged to remove the brushes, without removing the motor, on our Bosch WFD2460GB/01, and ordered replacements (from UKWhitegoods!). I appreciate the need to ensure the replacement brushes are fitted with the taper in the direction of motion of the motor shaft (as per the previous post). What I’m not sure of is: does the drum (viewed from the front, through the observation glass) rotate clockwise or anti-clockwise in use? (Guess who doesn’t usually do the washing!?) I did ask my wife, who says she’s never noticed… 🙄
    Please be assured I am a qualified electrical/ electronic engineer – just not usually working on domestic appliances (although I have in the past, from time to time).
    Thanks in anticipation.
    #161682
    Dave_Conway
    The drum spins both ways while it’s washing and that isn’t actually relevent to the brush fitting, it’s the angle of the holder on the motor as the new brushes have angled ends, Gegsy’s post above tells you all you need to know regarding fitting 🙂
    #161683
    Dav1dM
    Ah! I get it – the taper on the brushes is because they’re offset on the motor shaft! Thanks, Dave (and Greg!) – your help is much appreciated. Just one more question, if I may – would you usually try to replace the brushes without removing the motor (bit of a fiddle, and I haven’t tackled the harder bit – putting the new ones back – yet!) or would you remove the motor to do it? I thought of removing the motor (would make fitting the brushes easier, and I would have tried to clean off some of the old carbon dust which I’ve just ignored) but it would have been a bit more work and I would have had to re-tension the belt… Which way is preferable, would you say (or is it just a case of “six of one and half a dozen of the other”?) Thanks again…
    #161684
    gegsy
    Defiantely motor out its a bugger gettin the springs down guide out of motor nevermind with motor still on appliance 😉
    Dav1dM
    The new brushes arrived promptly this morning – excellent service! Thanks for the advice – you’re absolutely right; I wouldn’t have been able to get the new brushes inserted with the motor still fitted (well, maybe in a hundred years…!) So I followed your advice and took the motor out, and even then it was really quite a fiddle!
    I was a bit concerned that the connector plate of the new brushes was a bit narrower – and had slightly larger cutout slots – than on the original brushes. It made them a much sloppier fit in the retaining collar, and I had to bend the lugs in slighly to make sure the connector couldn’t flip out (with the spring pressure).
    Anyway, got it all back together and it works (gets me “Brownie points” with ‘er indoors !) so thanks again for your help.
