Re: Glass Shattered!!! Diplomat Select 620 Single Electric O
Were you grilling with the door open or closed ?
Most ovens are only designed for one or the other (refer to user manual). If this model is not designed for grilling with the door closed and you were that will more than likely be the reason.
Sometimes this just “happens” though, for no apparent reason.
If you can find the full model number around the door, AHY??? APL??? I can price the replacement glass for you.
I have deleted your duplicate post by the way.
