glass washer repair
  • #21345
    fasetester
    does any one know of any web site or forum that gives you any information on repairing glass washers are the any different to repair than dishwashers thanks :help: fasetester
    #190510
    paulpaddison
    Re: glass washer repair
    your best bet is contact the people who made it and get them to fax you a manual or section from manual of the arear you need to check, from experience last one i fixed burnt a wire off a heater. fairly easy repair but very thick wires bigger feeding pipe and drain pipe very well made pice of kit. ( if its a pub glass washer )
    #190511
    abbots
    i repair most makes of commercial glass/dishwashers. what is it that you need help with ?
    john
    #190512
    fasetester
    hi john thanks for your reply no fault to repair at the moment just wanted to know if there was a web site or a forum out there just wanted to read up on them and get some experience or know how so i would know some thing about them as i would like get some experience in commercial appliance repair also thanks paul for your reply 😉 ps i know where to come if i have any problums fasetester
    #190513
    welsh__boy
    my company only deal with commercial and industrial equipment, pm if you need any help.
    #190514
    fk
    http://WWW.classeq.co.uk
    This is the website for Classic glasswashers and has some wiring and parts diagrams
    #190515
    M1
    Re: glass washer repair commercial appliances !!
    Hi Can anyone help ??
    Hobbart DW Comanda (comercial) customer complains after about 10 cycles just stops. Then they leave it for a couple of hours & it goes again.
    I have checked the PCB for dry joints etc !!
    Any ideas Thanks
    #190516
    M1 wrote:Hi Can anyone help ??
    Try:-
    call.centre@hobartuk.com
    #190517
    Slippy991
    Can anyone help? Got a call out to a kromo aqua 40 glass washer
    They saying its slow to fill with water and takes ages to work.
    I’ve never worked on a glass washer before. Can some one tell me
    The sequence of which it operates, Is it like a dishwasher? Ie fills with water via
    The solenoid valves, pressure switch activates, motor and heater turns on??
    Am I far off the mark?? I know it has two heaters, one element in the tub and the other is
    A boiler type? Is there a delay before the wash motor comes on? So it heats up the water or something? Any help wud b great.
