Good morning all,
Wondering if anyone has experienced an unusual problem with the above m/c?
I have renewed the drum bearings and spider due to the bearings being severely worn.
However, now re-assembled the m/c trips out immediately a programme is selected.
The m/c has been laid up for 3-4 weeks awaiting the spider, so I wondered if the motor had got moisture into its windings etc.
However, I have tested the motor and it is fine.
If I disconnect the multi plugs at the control board for the motor and door interlock, then the unit does not trip.
The door interlock is also fine, as is the wiring/harness.
If the motor or other component blew the board, which looks ok, would the m/c continue to trip?
I didn’t disturb many wires when stripping the assembly, and struggling to locate the cause.
The m/c is barely two years old, and in good condition otherwise.
Best wishes,
Jon
