Gorenje auto WA50140
  • #61670
    senseib
    I changed the pump on this machine and now when it’s programmed up and press the start button the door locks but then the start led light starts flashing twice and nothing happens.
    Any advise please 🙁
    #347140
    gandh1
    Re: Gorenje auto WA50140
    accidentally tugged the interlock wires out ??
    #347141
    senseib
    No the door locks, the interlock wires are good!
    #347142
    bazza500
    Fault 2 is a doorlock problem.
    I have found on a few machines that the connections on the board where the door loom goes on burns away. Resolder connections and away ya go!
    #347143
    DDSDDS
    i have just done a gorenje with the exact same fault this morning and it was the track under the connector burnt away as bazza says very similar damage used ot happen on the remco indesit boards
    bit of solder and its up and running
