Gorenje BD8860E Timer
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Gorenje BD8860E Timer
Viewing 1 post (of 1 total)
  • #83355
    Farmerguy
    Hi there folks,
    Thought I might post some notes on just fixing my cooker.
    Bottom oven not heating:-
    Checked with meter.
    When R/T control set to oven and then temp set to on meter on,
    element went to zero ohms !.
    Checked element seemed OK.
    Checked all stats they seemed OK.
    Checked S/W all appeared working.
    Timer & clock all working OK.
    Time for more in depth look and test.
    Made up test lead for element, tested works OK.
    Made up test lead for stats, a paper clip can be used to loop connections if spade connectors not available.
    Everything seemed to be working in order !.
    Last thing to check timer works a relay which appeared to be working !.
    Fitted loop to relay, ie the two (2) contacts by relay and WOW, element now works.
    The relay contacts were working for volts but not for current !!.
    These time units are very expensive and can be fixed but I have just left contacts looped out (Shorted) as timer not needed.
    The Clock still works though.
    Hope this might be helpful to others as there not much out there on these items.
