Gorenje Built in Oven
  • #25657
    Steven
    My engineer went to this call month ago, blowing trip, tested it out, as usual no fault appeared would do this intermittanly.
    She has now called back to say fault is there again happening more now, any known faults with these?
    Thanks Steven
    #206911
    BobHope
    Re: Gorenje Built in Oven
    Hi Steven
    model number and art number will help.
    Bob.
    #206912
    Steven
    Gorenje Model EVP4442 IM B8980w Serial 31930021
    #206913
    BobHope
    Hi Steven
    has the customer reported any fault codes.
    Bob
    #206914
    Steven
    No; just to say its blowing her trip
    #206915
    Steven
    Correct model now EVP444-421M B8980 serial 3190021 (695273) 18 mths old working fine until last month, total wattage 3.4KW has been wired to 13 amp plug but is on the seperate cooker point. takes out the main circuit breaker for the whole house not the individual breaker.
    Single Oven unit built in blowing trip intermittantly when door is opened/closed
    Went there yesterday Megged all machine out all elements fine,checked door switch etc no visable signs of shorting on switches etc
    So put it on test heating up fine, temperature ok, open & closed door during heat up all seemed fine, then about 5 or 6 time opened door when the stat clicked in then tripped off.
    Reset trip started working again.
    Any ideas
    Steven
