Gorenje D8565nb dryer fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Gorenje D8565nb dryer fault code
  • #96759
    cornwell40
    Got one of these beeping three times, when start pressed, but nothing else. Any ideas on 3 beep code?
    ART. 454596 /model D8565NB
    #464723
    All I can find that may be of use is:
    [TABLE=”border: 0″]
    [TR]
    [TD] [TABLE=”border: 0″]
    [TR]
    [TD=”align: center”][/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]DRYING PHASE
    The drying stages.
    Phase1 – drying time on the beginning without humidity sensing
    Phase2 – drying phase with humidity sensor
    Phase3 – extra drying time on the end of phase 2 without humidity sensing to achieve optimal performance.
    Phase4 – extra drying (function) on the end without humidity sensing. Functional button S3.
    Phase5 – cool down cycle.
    Phase6 – anticrease[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]FUNCTION KEYS OPERATION[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]STEAM GENERATOR OPERATION (SG)
    Steam generator linen care.
    – Compresor and SG heater could works at the same time
    – Main pump and SG pump could works at the same time
    – Compresor operation equal as for normal drying phase
    Steam generator heater operation
    – The heater is switched on 2 seconds after the beginning of main motor rotation (CW or CCW) and switched off 2s before drum rotation stop
    Steam generator pump operation
    – Pump never works when steam heater is not on
    – Pump operation during cycle 0,1 sec ON, 0,5 sec OFF
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]PUMP OPERATION
    At the beginning of drying the pump switches on for 30 seconds to pump out eventual water
    For the first time it switches on after 5 minutes, and then every 2 minutes (from the end of previous cycle) and operates for 30 seconds.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]HEATER OPERATION
    Heater operates only in CW rotation.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]COMPRESSOR OPERATION REGIME
    The compressor is switched on 3 seconds after the beginning of drum rotation and switches off 3 seconds before drum rotation stop.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]FAN A OPERATION REGIME
    The FanA is switched ON/OFF as for measured temperature NTC 2 on Compressor high pressure tube.[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]DRUM LIGHT
    Drum light switches on each time the dryer door is opened. If the dryer is left for 5 minutes with the door open, the light switches off.
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]AIR IONIZER
    Air IONIZER operates only when function AirIONIZER is on. Air IONIZER add negativ ions into the drum with positive effect to the linen (softer fibers, easier ironing).
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [TABLE=”border: 1″]
    [TR]
    [TD]MAIN MOTOR[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]SPECIFICATIONS[/TD]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [TD]220 – 240 V[/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD]460 W (nominal 190 W)[/TD]
    [/TR]
    [TR]
    [TD]In[/TD]
    [TD]0.80 A[/TD]
    [/TR]
    [TR]
    [TD]Resistance[/TD]
    [TD]Main 39 Ohm auxilliary 38 Ohm[/TD]
    [/TR]
    [TR]
    [TD]Run capacitor[/TD]
    [TD]8 μF[/TD]
    [/TR]
    [TR]
    [TD]Cos φ[/TD]
    [TD]0,9[/TD]
    [/TR]
    [TR]
    [TD]Isol. Class[/TD]
    [TD]F, thermal protected[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]COMPRESSOR[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]SPECIFICATIONS
    [/TD]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Nominal voltage, frequency[/TD]
    [TD]220-240 V / 50 Hz[/TD]
    [/TR]
    [TR]
    [TD]Voltage range[/TD]
    [TD]187 ~ 264 V[/TD]
    [/TR]
    [TR]
    [TD]Input power[/TD]
    [TD]610 W[/TD]
    [/TR]
    [TR]
    [TD]In[/TD]
    [TD]2,8 A[/TD]
    [/TR]
    [TR]
    [TD]Lock rotor current[/TD]
    [TD]13.3 A[/TD]
    [/TR]
    [TR]
    [TD]20 µF / 370 VAC[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Water level sensor SG A, SG B[/TD]
    [TD]level switch SG A, level switch SG B[/TD]
    [/TR]
    [TR]
    [TD]Electrical Characteristics[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]Pnom[/TD]
    [TD]10W[/TD]
    [/TR]
    [TR]
    [TD]Switched Voltage (max)[/TD]
    [TD]DC200V, AC140V[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Level sensor 1 level reed switch[/TD]
    [/TR]
    [TR]
    [TR]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Level sensor 2 level reed switch
    [/TD]
    [/TR]
    [TR]
    [TR]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD]TEMPERATURE SENSOR NTC1 and NTC2:
    [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]T (°C)[/TD]
    [TD]Rnom (Ω)[/TD]
    [/TR]
    [TR]
    [TD]0[/TD]
    [TD]63346[/TD]
    [/TR]
    [TR]
    [TD]5[/TD]
    [TD]49578[/TD]
    [/TR]
    [TR]
    [TD]10[/TD]
    [TD]39076[/TD]
    [/TR]
    [TR]
    [TD]15[/TD]
    [TD]31006[/TD]
    [/TR]
    [TR]
    [TD]20[/TD]
    [TD]24762[/TD]
    [/TR]
    [TR]
    [TD]25[/TD]
    [TD]19899[/TD]
    [/TR]
    [TR]
    [TD]30[/TD]
    [TD]16087[/TD]
    [/TR]
    [TR]
    [TD]35[/TD]
    [TD]13080[/TD]
    [/TR]
    [TR]
    [TD]40[/TD]
    [TD]10694[/TD]
    [/TR]
    [TR]
    [TD]45[/TD]
    [TD]8790[/TD]
    [/TR]
    [TR]
    [TD]50[/TD]
    [TD]7263[/TD]
    [/TR]
    [TR]
    [TD]55[/TD]
    [TD]6030[/TD]
    [/TR]
    [TR]
    [TD]60[/TD]
    [TD]5031[/TD]
    [/TR]
    [TR]
    [TD]65[/TD]
    [TD]4216[/TD]
    [/TR]
    [TR]
    [TD]70[/TD]
    [TD]3549[/TD]
    [/TR]
    [TR]
    [TD]75[/TD]
    [TD]3001[/TD]
    [/TR]
    [TR]
    [TD]80[/TD]
    [TD]2547[/TD]
    [/TR]
    [TR]
    [TD]85[/TD]
    [TD]2171[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]HUMIDITY SENSOR
    Laundry resistance circuit (1 laundry, 2 control unit). Important junctions: vire-humidity sensor, drum shaft-brush.[/TD]
    [/TR]
    [TR]
    [TR]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]PUMP[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [TD]220 – 240V; 50Hz[/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD]10W (240V)[/TD]
    [/TR]
    [TR]
    [TD]In[/TD]
    [TD]74mA (240V)[/TD]
    [/TR]
    [TR]
    [TD]R[/TD]
    [TD]956 Ohm ± 8{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}[/TD]
    [/TR]
    [TR]
    [TD]B, thermal protected[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]STEAM GENERATOR PUMP[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD]16W (240V)[/TD]
    [/TR]
    [TR]
    [TD]In[/TD]
    [TD]0,08A[/TD]
    [/TR]
    [TR]
    [TD]R[/TD]
    [TD]1230 Ω[/TD]
    [/TR]
    [TR]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]MAIN HEATER[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [TD]220-240V; 50Hz[/TD]
    [/TR]
    [TR]
    [TD]Pn[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]STEAM GENERATOR HEATER[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [/TR]
    [TR]
    [TD]Pn[/TD]
    [TD]1300W[/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD]1500W (240V)[/TD]
    [/TR]
    [TR]
    [TD]R[/TD]
    [TD]~43 Ω[/TD]
    [/TR]
    [TR]
    [TD]2 thermal fuse[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]Drum light LED[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]Istart[/TD]
    [TD]30 mA[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [TD]12V[/TD]
    [/TR]
    [TR]
    [TD]Pmax[/TD]
    [TD]1W[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TR]
    [TD]FAN A[/TD]
    [TD] [/TD]
    [/TR]
    [TR]
    [TD]VALUE[/TD]
    [/TR]
    [TR]
    [TD]Un[/TD]
    [TD]220-240 VAC[/TD]
    [/TR]
    [TR]
    [TD]Frequency[/TD]
    [TD]50/60 Hz[/TD]
    [/TR]
    [TR]
    [TD]I[/TD]
    [TD]0.09/0.08 A[/TD]
    [/TR]
    [TR]
    [TD]P[/TD]
    [TD]21/18 W[/TD]
    [/TR]
    [TR]
    [TD]rpm[/TD]
    [TD]2600/3000 RPM[/TD]
    [/TR]
    [TR]
    [TD]Noise[/TD]
    [TD]56/60 dBA[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    #464724
    cornwell40
    Cheers Ken,
    #464725
    rickard
    [TABLE=”class: dxgvTable, cellpadding: 0, cellspacing: 0, width: 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}”]
    [TR]
    [TD=”class: dxgvHeader”] [TABLE=”cellpadding: 0, cellspacing: 0, width: 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}”]
    [TR]
    [TD]Error code[/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TR]
    [TD]Problem[/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TR]
    [TD]Cause or remedy[/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TR]
    [TD]Process (service technician)[/TD]
    [TD] [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [TR=”class: dxgvDataRow”]
    [TD=”class: dx-wrap dxgv”]F1[/TD]
    [TD=”class: dx-wrap dxgv”]F1 on display.[/TD]
    [TD=”class: dx-wrap dxgv”]• Open clamps/short circuit of the temperature sensor.
    • An error occurs if the connection between the control unit and the temperature sensor is interrupted or a short circuit between the temperature sensors. The program is stopped immediately.[/TD]
    • Connectors, connection to NTC sensor.
    • NTC sensor.[/TD]
    [/TR]
    [TD=”class: dx-wrap dxgv”]F4[/TD]
    [TD=”class: dx-wrap dxgv”]F4 on display.[/TD]
    [TD=”class: dx-wrap dxgv”]• Clogged filter, blocked air flow. An error occurs if permitted temperature of heat pump is exceeded.
    # Clean filters.[/TD]
    [TD=”class: dx-wrap dxgv”]• Cleaning the filters.
    • Check the NTC.[/TD]
    [/TR]
    [TD=”class: dx-wrap dxgv”]F0[/TD]
    [TD=”class: dx-wrap dxgv”]F0 on display.[/TD]
    • Error of the processor.
    # Restart the machine.[/TD]
    [TD=”class: dx-wrap dxgv”]• Control unit. [/TD]
    [/TR]
    [TR=”class: dxgvDataRow dxgvLVR”]
    [TD=”class: dx-wrap dxgv”]F3[/TD]
    [TD=”class: dx-wrap dxgv”]F3 on display.[/TD]
    • Pumping error.
    # Full condensate container.
    # Hose clogged.[/TD]
    [/TR]
    [/TABLE]
    #464726
    cornwell40
    Container empty but does give me an idea 🙂
    Many thanks
