Having a problem diagnosing a gorenje condenser tumble dryer fault. When start button is pressed on any cycle, the start pause light and the empty water tank light flashes continuously. Not sure whether is a fault code or is a pcb error. The drain pump tests of and the float chamber is clear, the dryer pumps directly into the drain so not a full tank fault.
Any advice or fault code information would be very helpful.
Check the system that detects if the tank is full, can’t remember what type Gorenje use??? (I know you said it drains directly out but worth checking just to eliminate!)
thanks for all the help. worked out that the pcb is selecting the start delay when start button is pressed. cheeked all the button mechanism, defenestrate pcb fault. gona be a write off unless anyone can give any tips?
