Gorenje WA1287 intermittent water leak
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Gorenje WA1287 intermittent water leak
Viewing 1 post (of 1 total)
  • #49552
    jontymox
    Hello everyone,
    Firstly, thanks to Penguin 45… The Candy w/m diagnosis was correct.
    The dispenser to tub hose was indeed blocked. Thanks again.
    I’m also having a spot of bother trying to diagnose and cure an intermittent water leak on the above Gorenje w/m.
    Upon inspection, the unit was bone dry save evidence of weepage from the soap dispenser, which also was deteriorating generally. I renewed this unit, as it was the only sign of a leak and I understand are prone to leaking.
    However, the following morning this leak/weepage re-appeared so I re-inspected. Everywhere bone dry again! There is no evidence of water leaking from the door seal, and it appears in good condition. Yet, I’m wondering if this is the source of the mysterious leak.
    Any thoughts/experience of this would be much appreciated.
    Best wishes,
    jontymox
