Gorenje WA6111 a/w
  • #52411
    Is there a soap box/drawer issue with these? Customer has one which randomly floods water down the front of the machine. Everything is nice and clean and the water pressure is not excessive.
    Cheers,
    Re: Gorenje WA6111 a/w
    hi chris..
    change the soap dispensor and everything will be fine…scale built up..suppose you want part number as well..
    bryan
    #311707
    Mmmmm…….. Might be nice.
    Thanks Bryan.
    ELDAR59
    chris, you could try putting a washer or two between the box and the cabinet, under the back screw.
    this obviously has the effect of angling the back of the box down and does work.
    cheers.
    #311709
    jontymox
    Chris,
    I understand you have probably realised that these, and other Gorenje W/M’s have soap dipenser leakage problems.
    Thay are prone to splitting…. or hairline cracks of the plastic casing, and renewal is the most suitable solution.
    They are available from ISDAL in the Wakefield area, although I’m not sure if that is anywhere near the Soviet Republic of Yorkshire!
    Best wishes,
    jontymox
