Afternoon
I have had my Gorenje WA7215BK machine trip the electrics a couple of times. it appears to be intermittent so im wondering what i can check
This is what ive checked so far
-Had the back off the machine and can see no evidence of leaks from the outer drum
-Cant see any signs of water leaks from around the bearings or from where the thermostat is
-Checked all the wiring i can see in the back and in the top of the machine, cant see any frayed wires
I had a look at the motor, im not sure if the motor uses carbon brushes or not but when i ran the machine i cant see any sparks indicating worn carbon brushes
I ran the machine both unloaded and unbalanced to see if vibration was causing any of these problems but it all looked OK
Does anyone have any ideas on what else i could check?
