Gorenje washing machine leak
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Gorenje washing machine leak
  • #69231
    mrhuggy
    Hi I have a Gorenje WA61121 that leaks from the soap drawer on the last rinse only. I have checked water pressure,replaced drawer conveyor, checked soap drawer hose for blockages,but to no avail. Any ideas? Thanks
    #374086
    ELDAR59
    Re: Gorenje washing machine leak
    try putting a washer between the soap box and the cabinet at the back end where the soap box fixes to the cabinet.
    this will lower the back end a little, encouraging the water to run away.
    you could also lower the front feet a little, raising the front end of the washer.
    the early models did have a slight problem with leaking soap boxes, normally sorted by changing the unit.
    cheers.
