Gran’s Bosch washer
Viewing 15 posts - 1 through 15 (of 18 total)
  • #22283
    robmarshall
    Sorry for the lack of model number but I’m looking for some general advice/.
    I am about to inherit my Gran’s washer dryer. It a old Bosch, bought new in 1987. It is VERY quiet indeed (quieter than my own WFL 2260) and thought it would be a good project as it was hardly used until two years ago.
    Two years ago, my Gran died and the house was rented out, the machine was used by the new tenants. Somehow they have seen it fit to saw the door off its hinges and tore the door seal.
    So, how easy is it to get parts for a Bosch of this age. It will need a door, door seal possibly an interlock. Also, it has a stainless steel outer drum; how easy is it to change the bearings.
    What do you reckon? It would be a shame to bin such a good quality appliance.
    R
    #194320
    Re: Gran’s Bosch washer
    Tough as old boots, the old Bosch machines. Everything is still available through Bosch – at a price. Certain components may be available as compatible spares, which can save you a fair sum.
    The drum bearings are housed in a cast iron cross-piece on the back of the drum. Eight bolts and it will fall off.
    However, for specific info, the model number is crucial.
    robmarshall
    It’s a V695 model. ONly had about 5 years hard work, used once a week othewise.
    Is it worth recommissioning in your opinion??
    #194322
    Found a door seal and the bearings – think I need the eNr number as well for the rest of it.
    robmarshall
    Right, it has arrived! It is a v696.
    Was very impressed when moving it even though it was extreamly heavy but seemed to be very well built compared to other washers: stainless drum, cast iron weight, and SO quiet when spinning. However, door seal is stained and drum has some movement in it, so suspect bearings need changing soon. However it looks like the rear of the drum “unclips” so hopefully, replacement shouldn’t be too bad. What are your opinion of these fairly pre-historic olf Boschees??
    However, some considerate t**t who was renting Gran’s house has snapped the door off, so I need a new hinge. Are they still available via here? Number on the hinge: 8000360 AB 6
    Also, are the drying mechanisms on these any good. Both elements glow up when the “T2” setting is on.
    Also, is there any chance of getting a handbook for it?
    Thanks again!
    Rob
    #194324
    Door seal – 18BS03
    Bearing set – 05SS02
    Hinge – 107638
    An eMail to spares@ukwhitegoods.co.uk will get things moving for you.
    The dryer section is always rubbish on these, BTW. No fan motor, so drying by convection only. Takes HOURS……..
    robmarshall
    E-mail sent!!!
    #194326
    robmarshall
    No reply received as yet. Any chance of a price incl. P&P?
    Also, can you price up a pump as mine is leaking slightly!
    Thanks!
    #194327
    Pump – 51BS02
    I will go and poke the Parts Maestro for you…..
    Dave_Conway
    robmarshall wrote:No reply received as yet. Any chance of a price incl. P&P?
    Hi Rob, the reply was sent on the 15th at 12.28pm, it may be in your spam box 😉
    Copied here for you:
    18BS03 Door seal at £12.95
    05SS02 Bearing kit at £19.95
    107638 Hinge at £7.50
    Please add £4.95 carriage with a 3-5 working day delivery time.
    robmarshall wrote:Also, can you price up a pump as mine is leaking slightly!
    51BS02 = £19.95 😀
    #194329
    I personally would not advise purchasing a 51-BS-02 pump for your machine. Unlike the more resilient standard Siemens made pump, they tend to go up in smoke if the impellor gets jammed 😯
    Your existing pump will only require a new shaft seal part number 051840 (available via spares@ukwhitegoods.co.uk) and a little 3 in 1 oil on each end of the shaft! 😉
    #194330
    robmarshall
    next stage of the saga: the pump! I have to be honest, I would like to replace the pump because, if the pic below works, it has been leaking for some time and also one of the hinges that attach the plastic section to the pump (secured by the metal retaining clip) is broken.
    Would a replacement pump simply bolt on, or are the original pumps still available for less than the price of a world cruise?
    Thanks again! (pretty pic attached – hopefully!)
    #194331
    There’s nowt much wrong with that pump the advice I gave earlier wouldn’t sort my friend!
    Lashings of WD40 will clean it up and refresh the bearings 😉
    #194332
    robmarshall
    thanks Martin but the plastic moulding section that forms a hinge at the rear of the pump is broken, so is that section replaceable or am I looking at an alternative pump?
    #194333
    No parts Rob, just the seal available. Martin is refering to to the (infamous) GRE pattern pump, which used to blow up if you smiled at it. The pump I quoted above is rather better quality and is good value at £20.
