Grill in a Hotpoint built in oven.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Grill in a Hotpoint built in oven.
  • #98848
    Clancampbell
    I have a Hotpoint oven, model No. OS897DC IX/HP. The grill element only heats on the inside bars, the outer bar does not heat up.
    I replaced the element and I still have the same problem. The outer bar, which seems to be like a separate element will not heat up but the bars on the “ inner element” work fine. Any ideas would be good to have! Thanks Mike
    #474023
    outer element is only used when your using the area as an oven
    can see an option for a small and large grill so you will only get one element
