Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Groaning noise during slow drum rotation after re-assembly
- This topic has 7 replies, 3 voices, and was last updated 8 years, 9 months ago by
PleaseNoteX.
July 4, 2017 at 10:20 am #91588
PleaseNoteX
ParticipantModel: Bosch WAE24468GB
Video of problem: https://www.dropbox.com/s/m1uebnmll6ilo … 0.mp4?dl=0
Took the entire machine apart to get at something trapped between the drum and outer drum. Put it all back together and now it’s making this noise, but not when spinning, only the slow agitation sections. There was no problem before I did the repair.
I am fairly certain the sound is coming from the hub. The central nut there was extremely difficult to undo and I tightened it very substantially during reassembly, but definitely not as tight as it was before. I did not apply lubricant anywhere during re-assembly.
July 4, 2017 at 10:46 am #448669electrofix
ModeratorRe: Groaning noise during slow drum rotation after re-assemb
are you sure you got the heater back in its holder ?
also does it make the noise if you remove the belt and turn by hand ?
July 4, 2017 at 11:24 am #448670PleaseNoteX
ParticipantRe: Groaning noise during slow drum rotation after re-assemb
electrofix wrote:are you sure you got the heater back in its holder ?
Hi, thanks for replying!
I’ve made some progress: the noise only happens when loaded and running… even then, not always. Absolutely fine when empty, even running a cycle. Tried hand-moving a drum full of still-wet heavy clothing, no noise then either.
It did take me a while to get the element back in. I could try re-mounting it but I was pretty sure I got it because it felt solid.
July 4, 2017 at 12:49 pm #448671Martin
It is important to remove the belt and try turning the drum as Dave asked. It should be virtually silent and spin easily. 😉
July 4, 2017 at 3:44 pm #448672electrofix
the heavy clothes put a downwards pressure on the drum. if the heater is above and not in its rear holder it may catch
take the front off and the belt. with 1 hand push on the heater terminals to force the end of the heater up and with the other turn the drum slowly
the sound the noise is making does have a quick pattern to it. if its not the heater then I would look at the motor and see if there is any bearing play
July 5, 2017 at 8:35 pm #448673PleaseNoteX
electrofix wrote:the heavy clothes put a downwards pressure on the drum. if the heater is above and not in its rear holder it may catch
Can’t thank contributors enough, your generosity with time is much appreciated.
Touched the heating element to the drum and it sounds like the end of the world, definitely not that. Re-fitted it anyway, seems fine, and zip-tied some parts that may have been straying. I’ve had my ear all over the place and can’t pin down where the noise comes from.
Hand turning results:
– Empty, Belt on: quiet “wheeeeeeeeeeeeeeeeeeeeee noise.”
– Empty, belt off, dead silence.
– Heavy load, belt on, “wheeeeeeeeeeeeeeeeeeeee”.So it seems that grinding only occurs by *powered* motor, since it happens at very slow speeds and I can’t trigger it by hand.
July 5, 2017 at 9:02 pm #448674electrofix
did you look at the motor ?
July 16, 2017 at 10:53 am #448675PleaseNoteX
Hi, sorry I was away for a bit.
I ran the machine on a spin with the belt off an can neither see nor feel any play whatsoever in the part that rotates the belt.
When I disconnected the motor I padded the underneath with towels so it didn’t drop or damage, I’d be surprised if I’ve done anything to it.
