only by finding connections and disconnecting them
if you do it in the fridge you have to make sure no moisture can get into the open wires
if you do it at the pcb looks like you would have to cut a wire as they use multi connections
thanks! the fridge is in a bedroom and it disturbs my partner when I open it! what happens if I tape over the button which releases when I open the door? Would that be an easy solution? It looks like the leds are part of the thermostat is that possible? I can disconnect the board with the lights on it but I think that board does more than just the lights
Thanks for the tip. So does anyone know how to do this properly? Any help would be appreciated. Doesn’t make sense that you have to have the light come on. Thanks in advance.
