grundig GTN38250HGCW weird fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries grundig GTN38250HGCW weird fault
  • #99065
    cornwell40
    Loverly heat pump dryer, the customer hasn’t registered the 5 yr guarantee [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/icon_neutral.gif”}[/IMG2] and has a good fault after 3 years.
    Switched on and it worked fine on first test, second time counts down but totally silent, doing nowt. Customer reports that it’s been like this for a few months and if he leaves it it will start up after about 20/30 mins but it takes ages to dry ( really ??[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/icon_wink.gif”}[/IMG2])
    Opening and closing the door registers but the lamp doesn’t come on in the drum.
    Any ideas on this because I don’t normally touch the heat pump stuff.
    Cheers
    Tony
    #474904
    have emailed you all i can find
    cornwell40
    Thanks Dave, much appreciated.:)
