Grundig GTN39250CGCW not starting
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Grundig GTN39250CGCW not starting
Viewing 12 posts - 16 through 27 (of 27 total)
  • #476080
    Zappaking
    Yeah. Usually it runs for a few seconds, stops but the timer runs down, then randomly starts again after 5-15 minutes.
    #476081
    Foxrobin
    Ours is exactly the same, just outside its 5 year warranty…. Was there a final diagnosis on what it was??
    #476082
    Mafro
    Hi everyone
    our tumble dryer has now done exactly the same thing!
    just outside of the five year warranty. So frustrating. Has anyone had any luck with this before we simply buy another tumble dryer (won’t be a grundig one!)
    many thanks
    matthew
    #476083
    ok describe fault exactly and post your model no
    Mafro
    The exact same issue as previously posted here before
    dryer stops drying but timer continues to count down. Sometimes it starts working again when disconnected from mains. Mostly not. Doesn’t matter which programme. Door sensor is working
    model number is GTN39250CGCW
    #476085
    difficult to say what it could be
    model no you quote seems to be wrong as i get GTN39250GCW
    but there seems to be 2 versions depending on commecial code wich is either 7188289890 or 7188283060
    when it stops does it goes completely silent or is there still some noise ?
    if it still makes some noise its poss motor if not it does sound like the board.. If its been plugged on for 5 years you might find domed capacitors on the board which may well cause this
    Mafro
    My apologies. The model number you typed is correct. And it’s 7188289890
    the dryer goes completely silent and timer continues to tick down. If it’s the capacitors on the board, how do I go about fixing?
    your help is much appreciated! So frustrating. If it’s not fixable we will have to buy another soon
    #476087
    https://www.robotroom.com/Faulty-Capacitors-1.html
    if you find any then you get the correct value ( uF and voltage) and solder in new ones taking great care to solder them in the correct way round as they are polarity concious
    Mafro
    Thanks so much for this
    im not very handy at this sort of stuff but will have a look at the board and see if I can figure out if the capacitors are gone
    Thanks again
    Matthew
    #476089
    Petrea
    Hi all. I have the same problem. This happened twice. Last time I plug off the dryer for one day. While off I pressed most of the buttones. I cleaned and the sensor located on lower part under the filter. Next day I plug on the dryer and used 5 times since with no problem. Not sure if is just luck …. Just give a try.
    #476090
    allanzhou
    I encountered the same issue. The dryer stops working after running for a while, but the screen and program timer continue to function normally. This problem seems to occur randomly—sometimes I can run the drying program for an hour, and other times I can complete the whole cycle, but sometimes it won’t start at all.
    What I can say for sure is that when the problem occurs, the light inside the drum is not working (under normal circumstances, the light inside the drum should turn on when you open the door after the dryer is powered on. If the light is not on, it definitely indicates a malfunction). Maybe we can find a breakthrough here?
    I’ve already disassembled the dryer and tested some components with a multimeter. I can confirm that the thermal sensor is fine, and the capacitor is also working properly.
    Has anyone managed to fix this issue? If so, could you share where the problem lies?
    #476091
    EverUsualSuspect
    Hi all. Just thought I’d join and tag on my experience. I’ve had the same problem that has been talked about on here. From what I can tell, I’ve managed to fix the problem but cause another. The original fault was that it was stopping with no reason or indication. As far as the panel was concerned, it was drying but nothing was turning. Unplug it for a period and it would spring to life. As others have said, it sounded like a an over heating issue. Considering the mains was going straight to a PCB as the first port of call, I suspected that would be a good place to start. It’s never easy to see bad solder joints so I just removed and resoldered what I considered doable on the board. Put it all back together and something had changed. The week before, I had taken a short look and found that I could run the machine as long as the sides were on. This time, I tried to run it with the top panel off and it would start and then instantly stop, going into Pause mode. I thought my gamble hadn’t paid off and it was now time to buy another one. But I then found that when I put the top on, away it went. It did a 2 hour cycle, merrily. Happy days.
    Since then though, the M-in-L (it’s not my machine), reported that it went back into Pause the next day. I told her to whack it and off it went again. Seems to me that I may have fixed the original problem but at the same time caused another! I can’t see anything obvious as far as an intrusion sensor goes. Does anyone know how Grundig or Beko do this?? Is there a light sensor? It’s frustrating.
