Grundig washer GWN48430cx – powers up, locks then beeps and no action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Grundig washer GWN48430cx – powers up, locks then beeps and no action
  • #96319
    twicknix
    I couldn’t find any clues on what it would be. The customer says it was not filling with water, when I visited the machine, basically you turn the power on, the display lights are on. Select for quick 14”, then press start. It locks and beeps (assuming that is usual for it to do so), then clicks – nothing happening apart from lights on and no one’s home.
    I put my mindset into Beko washer with induction motor fault finding, no motor power board. It appears to be that the fascia panel controls it all? Not something that I have come across before.
    There is power to the water valve but doesn’t activate presumably it does not mean water valve is the culprit as I tried to set it to spin and drain which should bypass the need for water and *should* activate pump and drum action but it didn’t.
    Am I looking at control panel on the fascia being the culprit?
    #462986
    think motor power board is part of motor but some info shows it clipped to chassis by the dampers
    it is as you say beko built have got the complete manual inc test routine if you want
    there are 2 models with same number so just in case of differences need commercial code
    its either 712641100 or 1300
    AMS
    Child lock accidentally engaged?
    #462988
    twicknix
    no child lock engaged.
    It was a very confusing one.
    Commercial code is 7142641100
    Any chance I can have a test sequence manual, please?
    #462989
    done check your email
    twicknix
    Thank you.
