Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › GU15DA50GB Siemens Freezer – No Defrost Outlet?
- This topic has 2 replies, 3 voices, and was last updated 12 years, 8 months ago by
stevev79.
August 17, 2013 at 8:37 am #76718
stevev79
ParticipantHi all!
I am currently in the process of replacing all the appliances in my kitchen.
Last week I purchased a Siemens built-under – integrated Freezer GU15DA50GB from a local dealer.
The freezer arrived and was installed successfully. At the end of the installation process I asked the engineer how I would go about defrosting the freezer and would it be possible to point me to the defrost water outlet. Unfortunately, we could not find a defrost water outlet, which leads me to my question for the forum….
The product specification for the model GU15DA50GB clearly states on the Siemens website, in their catalogue and on dealers web sites that this model includes a “defrost water outlet – For easy convenient defrosting”. See here:
http://www.siemens-home.com/ie/our-prod … A50GB.html
My first port of call was the manual, I could find any mention of this feature. The manual actually says that I must “sponge out”.
I then called on the dealer who then referred me to Siemens Customer Support. After speaking to no less than three customer support advisors at Siemens I could not get a straight answer. They promised to call me back after contacting Germany, however it has been several days and no one has made contact.
As you can imagine I am a little disappointed because it would appear that I have paid for a feature of a product which I have not received.
Should my freezer have the defrost water outlet? Does anyone else own this model with the defrost water outlet? What is your opinion?
Thank you for your help in advance.
Kind regards,
Steve.
November 11, 2017 at 2:30 pm #399547k61
ParticipantRe: GU15DA50GB Siemens Freezer – No Defrost Outlet?
Hi.
Did you ever receive a reply from Siemens, only I am having exactly the same problem with deforsting. It’s a very poor design…November 11, 2017 at 8:12 pm #399548don
ModeratorRe: GU15DA50GB Siemens Freezer – No Defrost Outlet?
I apologise for what is going to be a long post :eeek:
First of all to answer the OP and your own question the instructions used for both of your appliances is a generic one used for all Siemens freezers. You will see from the attached picture you only get a feature where that section has either a dot or a reference to it.
In the case of the thaw water drainage this particular model does not have this function.
As this appliance is a self defrost system the defrost instructions again on the attached picture is generic across all non frost free freezers irrespective of brand.
So you are not missing out on anything and your freezer is a manual defrost as per the attached.
HTH 🙂
Don -
