GW 709 Washer
  • #9878
    domspeed
    at the rinse stage this eveing. I have tried turning the unit off, then on etc. It will only operate now for a few seconds and only momentarily. ie if I start another new wash cycle, it starts filling ( hot or cold ) then stops. If I try to rinse, or spin, it starts to pump out the water that’s still left from failure, then stops, starts, stops etc. Then, with all my attempts, it just beeps and displays a series of lights on the wash indicators as follows:
    there are 8 lights… the 3rd, 5th, 7th & 8th are lit.
    Any help would be MUCH appreciated. Even just the diag codes.
    I have been a mechanic for 19 years FYI 🙂
    Thanks so much in advance,
    Dominic
    domspeed@msn.com
    #136458
    alexa
    Do the diagnostics I’ve sent you and post back the error codehowever it looks like the Out of balance switch is RS
    #136459
    Re: GW 709 Washer failed
    The error code in binary is 00101011 which is 43 in decimal.
    The code book says
    “OOB Switch Fault”
    i.e. Out of balance switch
    Primary Source: Mechanical. Check switch is free to move. Check wiring harness is not blocking movement. Check switch operates correctly when activated, replace switch if suspect. If signs of corrosion, replace switch and harness, and fit condensation kit if not already incorporated in top deck. Check smartdrive is level. Check bias spring is fitted.
    Secondary Source: Wiring. Check harness to OOB switch is connected correctly. Check connected to normally closed position. Check for corrosion as above.
    Tertiary Source: Motor Control Module. Replace.
    Hope this helps.
    #136460
    alexa
    You’ve got it in 1
    Proceed as per above ensuring power is off
    #136461
    domspeed
    What can I say.
    You guys have really helped me a lot. It looks like everything is pointing to the OOB switch. Its ordered. Now, how do I buy you guys a beer?
    Thanks very much guys, seriously.
    Dominic
    #136462
    Alexa’s down your way – the rest of us’ll make do with a virtual pint :beer:
    domspeed
    I really am fortunate that this place is here for me, otherwise I have no idea how I would have found the info I needed. I hate guessing and “parts fitting”, and I didn’t have to. Thanks again, and I will post how I go after the part arrives…possibly today.
    I was also wondering how I go about getting the condensation kit, as one of the connections was very badly corroded.
    Cheers
    Dominic
    #136464
    Very simple solution to contact corrosion – grease. Plenty on the switch contacts will keep the steam off, and it won’t conduct. Your switch is in a little box, so any excess won’t drip into the drum.
    Cheers,
    alexa
    It gladens my heart to here such effusive praise for the best bunch of guys who only want to give great service and who happily go without reward to assist the unfortunate consumer who has to put up with the same crap products that we do.
    Moisture and a constant voltage (albeit low voltage) causes corrosion.
    Your model will not require a condensation kit
    Your replacement switch may well be a upgrade to get around this problem.
    Certainly put grease or vaseline on the switch terminals after pushing these on if the switch is not an upgrade.
    A piece of heatshrink tubing with glue lining (JAYCAR Part No. wh5602 or larger Ph. 1800 022 888) would be a better option as grease may disrupt the low voltage as would a spray on corrosion prevention product such as WD40
    The trick with any damp situation is:
    1/. Turn off at the wall after each use
    2/. Avoid steam from dryers or hot washes or hot water.
    3/. Fit a surge divertor as used on computer power plugs
    4/. Ensure touch pad is not cracked
    5/. Heat the room if condensation (steam) is likely to occur
    A stiff nylon brush where corrosion is and a spray with a WD40 style product (I prefer Inox) can resurrect an electronic board but again beware of spraying switches.
    #136466
    domspeed
    Again, thankyou a thousand!!
    I have fitted the new switch/harness assembly and the machine is once again working 😀
    I am very happy to take on all the extra info you guys have taught me.
    Dominic
    #136467
    alexa
    An absolute pleasure to have been off assistance
    and should you or any of your colleagues, peers, relatives etc ever need assistance then mention this web site and my colleagues will be only to happy to asssist
    #136468
    domspeed
    I was hoping that would be the case, and that is exactly what I would like to do.
    Bye for now 8)
  • The topic ‘GW 709 Washer’ is closed to new replies.
