Re: GW700 stops while washing and beeps
Fault code 130
Likely cause can be Rotor position Sensor(RPS)
Can be corroded contacts On RPS
You will have to check underneath washer for any signs of water leakage
A washer of this age can have main seal problems (IE Water leaks slowly from main shaft eventually finding its way to the Motor area where RPS is situated)
If this is the case time for a new washer.
Second cause can be a faulty motor controller
New Controller comes as kit Part# 425243KIT $240.00AUD
Best case is if it is just a faulty RPS Part # 420296 $50.00
