GW708F fault code 1011
Viewing 1 post (of 1 total)
  • #41899
    twopies
    Apologies for the post in two forums, the text below is a copy from the Australasian forum, but I need some advice and I might get more exposure here.
    I think I am up for a new Control Board, but just want to be sure prior to purchase.
    I have checked that there is no water in the pressure tube before reconnecting to transducer, and that it is not blocked.
    Regards
    twopies
    UKW New User
    Posted: Mon Dec 15, 2008 6:07 pm
    Hi there would appreciate help on this one.
    Initially just stopped after filling with normal display full cycle remaining.
    Cycled power, attempts to fills with random intermittent solenoid action.
    Then stops with error code 1011.
    All looks okay, will show same fault if advanced through to spin.
    Bowl is full of water and dirty laundry!
    Have pulled apart nothing obvious, put back together no joy.
    Any help appreciated. Thanks.
    Click here to go to the UK Whitegoods online spares shop
    Can’t find the part you need? Simply click here to use our spares Helpdesk
    twopies
    UKW New User
    Posted: Mon Dec 15, 2008 7:33 pm
    HI
    Just put this thing back together again after checking hot & cold solenoids and drain pump which are all good, blew down the pressure pipe, all clear.
    Machine started fine on cold wash, auto level, high spin speed. Filled fine, washed full cycle, moved to rinse and drained, refilled and agitated for couple of minutes then stopped with both rinse lights and spin light remaining in cycle. No indications that there is anything wrong except that is not continuing cycle. Can advance cycle but still no go.
    In diagnostics mode, upon entering I only get a single beep now with low water level light on and code 1010. scroll with spin speed to low water level and hold on and code 1001 is displayed. Scroll to low water level and hold and slow on and code 1011 is displayed, so I guess that this 1011 is the actual fault code? What does this mean?
    Solenoids and pump still check fine.
    Help, its days before xmas and I cant get a serviceman, I am a sparky, industrial electronics tech, avionics engineer, and telecommunication network engineer, so I can do the work, I just need the tech info.
    This is a great forum and help is much appreciated.
    UKW New User
    oined: Dec 15, 2008
    Posted: Mon Dec 15, 2008 7:42 pm
    Okay from what I have read the 1011 code appears to mean that there is a pressure sensor (water level) fault. This must be intermittent as it filled on auto when I put back together washed then filled for rinse. Just drained manually in diagnostics mode, reset and tried again, now wont do anything just sits with full cycle progress to go displayed. Waiting for a fault code to appear but not doing it….. Diagnostics shows 1011 code again.
    I am picking intermittent pressure transducer, anyone agree? I think I will rework the solder joints tomorrow night and see how it runs.
    Any other ideas or help or encouragement much appreciated.
    I don’t want this to beat me, and I need clean clothes to go on holiday!
