GW709 IS A Phase 5
Fault code 9 Size error
Reset Size
Size setting mode press &hold water temp up then press power
cold water led 5 Kg
low water led 6 kg
spin hold led 7 Kg Your case
Press power to store in memory
Thanks for that I saw it was that as I have the Phase 5 fault codes but as machine has been used for an extended period did not think it would be that simple. I take it that the 709 is a 7kg machine
If you can advise on this and once again many thanks
