gw709 has a bowlful
  • #12924
    bowlfull
    hello fellow forum users,
    I have read a few of the other posts and cant seem to find exactly what the problem with my machine is.
    Most of the time the w/m works with out a drama.
    When it comes to empty after washing, the pump starts and with excellent water flow. Then it decides to stop pumping for anywhere between 1/4 second to about 3 seconds, then starts pumping again for about another 5 seconds. (All the while the pump is actually pumping there is excellent water flow so blockage doesnt appear to be a problem)
    This pumping and stopping continues to get worse with less pumping time and more time doing nothing. Then between pumpings there seems to be a noise that sounds like a welder coming from under the bowl. (The welding sounds like a quiet arcing and is intermittant and random and tends to get worse in that its ‘buzzing’ most of the time. There is NO burning plasic smell at all.)
    I have powered down the machine and the buzzing continues untill its switched off at the wall. After 5 or so minutes I can restart the machine on the rinse stage and try to empty the bowl and the same happens as above.
    I have also managed to get into diag mode as I have read in other posts by holding down the water level down button when power on is pressed. Then spin speed up untill hold and slow are on.
    The result is: 00100101
    Now that I have all this down, I tryed again to complete the cycle and it performed with out a drama. 😕
    Any help would be appreciated
    Cheers
    Bowlful
    #152269
    Re: gw709 has a bowlful
    Follow the instructions here: http://www.ukwhitegoods.co.uk/modules.p … pic&t=6736
    If it doesnt rectify the problem, let us know. 😉
