Gw709 won’t fill
  • #18567
    kissenger
    Got a gw709 washing machine. When I start a new cycle the motor begins but no water flows. I seem to get error code xx00xx0x, x=off o= on,
    What does this mean and can someone please confirm error checking procedures for this model and or resetting.
    #179468
    Re: Gw709 won’t fill
    Hi Henry,
    Code 00110010 ( 😀 ) is a fault with the hot water valve or circuitry. Solenoid coil should read 64ohms, check cabling for continuity and dirty contacts.
    Power off when the deck is off.’
