GW711 Error code 00110001
  • #18386
    CBR600F4i
    Hey can i get help with htis pls, BTW great web site, ok from reading others i got into Diagnostic mode and got 00110001. I don’t have an advance button but the spin still made th hold and slow lights come up.
    This code also comes on as soon as i turn on the power and constantly beeps. To get the code i had to turn off at the wall and then power up using the buttons.
    Thanks for the help and again great site.
    #178829
    Re: GW711 Error code 00110001
    Hello Mr Honda……
    Your code is for a fault in the cold water fill circuit. Faulty wiring is common, or the valve solenoid is faulty. You should get a reading of approx 64ohms. If it has failed, you will need p/no 420148 = the proportional inlet valve.
    Power off when poking about inside.
    CBR600F4i
    Thanks for that, i will get in and check now or long weekend is over and i need to wash. he he.
    I Gather i need to break the silver warranty tab and open the brown circuit board cover to access terminal ends to check the ohms.
    Also the valve has a white label with 319403 and what looks to be a build date05/03 or may 03 which would make sence as i purchased in oct 03. Does this number have any reference or just an assembly thing, the valve has a 24v stamp. Do these push into a grommet or seal on the mixing tank that they sit in ?
    Thanks Again and in advance
    Mr Honda
    #178831
    If you start with the impedence test on the valve coil, you may not have to disturb the module/wiring at all. The valve is a push fit into the grommet, again, no need to disturb it yet. If you get about 64ohms through the coil, then you’ll have to delve deeper.
    CBR600F4i
    Hi Again, sorry for the delay , Long weekend out here downunder.
    Ok i have checked the coils and have the same 64ohms on both !!
    Where should i start probing to next ??
    cheers
    #178833
    Ok, so now you’ve got to the electronics end of things – trace the wiring back to the board, slip the connector and repeat the resistance test – should give a very similar reading. If OK, you’ll need to check whether or not you’re getting 12vdc to the valve.
