Hi folks
Went to this the other day and changed facia/control panel and door lock – straight forward it would seem but was having one of those afternoons :cry:.
Put all back together all working ok but no indicator lights – checked and retightened all the push on connector blocks to no avail. Sent both indicator module and main module to EMW for testing but they dont touch them.
Anyone had this fault? Is it most likely to be indicator light module or main module causing the problem? Or have I pulled a connection off somewhere altho wiring looked secure and checked all other connections.
Just thought – broken wire in ribbon cable between the two modules?
Any comments appreciated as usual.
Mick
