Haier
  • #48842
    spimps
    Very impressed by their committment to quality and customer care according to their web pages,pity their products are so poor.
    Built in fridge freezer today the first haier product I have come across,makes lada look quality.
    #297894
    robbra
    Re: Haier
    Try their washers, I’m getting expert at putting motors in from underneath the machine. Serial motor failures, sometimes on first wash 😛
    #297895
    cornwell40
    Re: Haier
    Aye, worked on quite a few of them Lada fridges 😉
    TC
    #297896
    LJDomestics
    Re: Haier
    Do these machines have a out of balance sensor also? had a question from someone today that was telling me they have one that only spins now and then.
    #297897
    Re: Haier
    I think Helo will tell you that it’s a pcb/software fault.
    LJDomestics
    Re: Haier
    Thx penguin,so they would need a new pcb. Are they needing setup like the indesit/hotpoint modules?
    #297899
    Dales-Electronic
    Re: Haier
    No plug and play 😀
    #297900
    BobHope
    Re: Haier
    yep you need to snap off a tab or 2 and set it up for the correct model.
    Bob.
    #297901
    robbra
    Re: Haier
    yes, they do have an OOB load detector and it is quite sensitive.
    #297902
    LJDomestics
    Re: Haier
    So is the sensor on the pcb? If so then a new PCB will surely have the same sensor?.
    Can they not be bypassed?
    thx.
    #297903
    robbra
    Re: Haier
    Like many it is within the motor circuit and relies on the motor revolving smoothly before the spin and therefore smaller loads that tend to drop more in the distribute cycle disturb the rotation and trigger the oob situation. Making sure the belt is tensioned on some makes, not possible on a Haier, can cure it but it is set on the pcb when manufactured and cannot be bypassed. The best way to test is to set on spin empty and if it spins then the loads are causing the no spin and best solution is to increase the size of loads being washed
    Rob
    #297904
    helo_75
    or change the pcb.. the softwares different now, it needs changing
    #297905
    robbra
    Re: Haier
    Interesting news, when did that happen and where did you find that out as according to Haier nothing has changed?
    #297906
    LJDomestics
    Re: Haier
    Can anyone confirm this is a model number that ive just been supplied by hopefully a customer…
    hw-c1460tveme-u
    #297907
    don
    Re: Haier
    Its a 1400 spin autowasher according to the link.
    HTH 🙂
    Don
