Haier 7KGA+A error message
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Haier 7KGA+A error message
  • #64727
    phillron
    I have a low budget washer that has performed excellently for the past 2 years
    We recently had an error code come on the machine reading err 7
    I am a fully qualified electrician and have some understanding of control and motors but am a complete amateur when it comes to these appliances
    I looked up in the little foriegn user instructions and the only reference was err 7= motor error
    The motor itself is running and the pump is emptying the water,however, the programme doesn’t complete its cycle before the error message comes up and stops that cycle
    I would appreciate information on what this error message means and whether the probable cause would be worth having it repaired,as opposed to getting a replacement
    I thank you for any response that you may be kind enough to make.(money is tight and we are hoping for the best )
    #357896
    phillron
    Re: Haier 7KGA+A error message
    Having searched for information
    I have now sorted what was a very simple problem, I hope the solution may benefit someone having a similar problem in future
    I removed the rear plate for investigation and eventually found that the socket that supplies the washer motor was not making adequate contact on all pins
    With a bit of playing about.I was able to get a much better contact and error message dis appeared and now runs fine
    #357897
    helo_75
    for a ‘fully qualified electrician’ that was a poor answer
    ill give it 4 washes
