Hi Franz
Sounds like a Module but did you pause first then switch on/off button off Then reset by control to Zero then switch on… then set to desired programme then start.. coz these haier machines have some quirky details and to reset must be done in this mode When you start this procedure the machine is on with display showing 11 mins Then start procedure Hope l have’nt confused the issue The PCBs are quite cheap on these machines
