Anyone had an issue with water volume on the rinses on this washing machine? The wash filling is fine as it starts to fill with water after a few seconds it pauses to allow the water to flow into dispenser hose and drum – does this ok until water level is correct and continues the wash. However when it gets to the rinses the water doesn’t pause at all and so as the volume of water pouring into dispenser and hose backs up and then over flows through a cutout in the dispenser box and down the front of the machine. The hoses are clear no restrictions. The water pressure is ok and hasn’t been touched. The dispenser box is clean and no blockages?
