Does any one know where I can get a bearing kit for this please or part no’s for individual bearings or if anything else is compatible? Connect cannot supply for this model. Cheers Kez
OK Kez, here goes but unsure where you can get the parts.
0020202766 – tub front
0020300464 – tub seal
0020102494 – inner drum
0020802745 – drum support
0020400524 – heater
0020202761 – tub rear ( no bearings )
0020102392 – bearing
0020102393 – bearing
0020300440 – bearing seal (bearings and seal are same for 7kg)
0020600091a – pully bolt
0020102869 – pully
0020100011 – element support
00215000036000 – tub screw
for 7 kg version the inner drum and outer are as follows
0020802853a – inner drum
0020802745a – drum support
0020202760 – tub front
0020806090g – tub rear ( no bearings )
just measured them for you
small bearing is 52mm outer, 25mm inner, depth 15mm and marked 6205-2z and was in a SKF bearing box – made in France, explorer series
the larger bearing is 62 mm outer, 30 mm inner, depth 16mm and marked up 6206-2rs
hope this helps
