Haier W/D (i know its a hoover)
Mod. HJA8703
Prod/S.N. 08133578/31800058
Ok, went to customers house for ‘no spin’. Found no motor action at all, so went straight to the motor/module to have a look. Found module blown due to motor loom chaffed through onto the module heatsink. Customer wanted new board so i ordered and replaced it(also repaired chaffed wire). Proceeded to test appliance and seemed to work ok, motor running nicely. Re-installed and tested again to be sure, filled, motor started, heater kicked in and looked ok….after about 2 minutes(once heater turned on) the machine stopped and i got 11 flashes (Dryer board/wiring faulty). Re-checked wiring, looks ok and resistance readings all ok, no earth leakage etc. Any ideas or has anyone come across this problem before?
