Halogen ring and light not working…most likely cause?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Halogen ring and light not working…most likely cause?
  • #22877
    jonobaker
    I have a Diplomat Select 620 electric oven and Diplomat hob. One of the large halogen rings on the hob has stopped working, along with the master light that signals when a ring is switched on. All the other rings work fine. Is it likely to be something I can have a go at fixing myself or am I better getting somebody in?
    Jono
    #196384
    Re: Halogen ring and light not working…most likely cause?
    Hi Jono,
    They are a bit of a pain to get into TBH, it sounds like the regulator but the only way to be sure is to get in there and test it out with a multi-meter.
    jonobaker wrote:Is it likely to be something I can have a go at fixing myself
    No Jono, seek expert help by clicking on the link below or going direct to http://www.extracareservice.co.uk 😉
