Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hardwiring a Hisense oven
- This topic has 5 replies, 2 voices, and was last updated 5 years, 4 months ago by
liam01.
December 1, 2020 at 6:14 pm #98741
liam01
ParticipantHopefully someone can help and tell me where i’m going wrong.
I’ve recently bought this oven that needs a 16amp power supply (https://www.currys.co.uk/gbuk/household-appliances/cooking/ovens/hisense-bi5228pbuk-electric-oven-black-10200559-pdt.html) but I can’t get it to work. I’ve hardwired it in using this 2.5mm cable, which is rated to 20amps (https://quickbit.co.uk/black-flex-cable-3183y-per-meter-3-core-2-5mm.html)
I’ve got an MCB in the cellar as below – It states 30A / 240v on the MCB itself, however when I turn this back on, the oven doesn’t come on? My previous oven worked fine on this setup. Do I need a lower Amp MCB?
Any help would be much appreciated.
December 1, 2020 at 6:59 pm #473617electrofix
Moderatorfirstly that a cartridge fuse not an MCB
An MCB is more accurate and can be reset wheras a fuse needs to be changed when it blows
you need to check there is power getting to the oven. both live and neutral
if no then you need to find out where in your house wiring the fault is
if yes and you have connected it correctly then the oven is faulty
December 1, 2020 at 7:14 pm #473618liam01
ParticipantThanks for that, I’d read something that made it sound like I had an MCB so good to know what it actually is.
There’s power still getting to the oven as the hob still works, and when my previous oven stopped working, I got someone out to look at it and they were able to get it turned back on again. Regarding wiring it up, i’m certain I’ve done it correctly – Matched them up in the junction box where the power comes and splits off to the hob, and followed the guidance for attaching the cable at the oven end.
December 1, 2020 at 7:46 pm #473619electrofix
Moderatorfrom the sound of thst your new oven is a dud
December 1, 2020 at 8:39 pm #473620liam01
ParticipantOkay, thanks for that. I’ll probably get someone out to look at it then to confirm before I see about returning it.
December 1, 2020 at 9:04 pm #473621electrofix
Moderatoryou could find a plug and a wire
then connect it to the lead and plug it into a socket
if its still dead its faulty
if it works then you have a supply problem somewhereconnecting to a 13A fuse as a quick test is ok it just cant be permanent
