Re: HAUS WM-1050W Control board?
if timer says motor overheats then there has to be a way of detecting it.
there is either a stat in the motor winding that is tripping, wiring to the motor that is going open circuit or the printed circuit board.
Does machine turn motor both ways ? if not look for fault reverse relay on board. look at all relays solder joints with a manifying glass you may not be able to see damage with the naked eye
dont know this machine so thats all i can suggest
