Haus WM1050w 7 flashes.
  • #64813
    Madmac
    Yes, I know, should just tell ’em to throw it in the skip 😯 Thought I’d try to help this elderly couple if I could.
    Machine wil run for 10secs and then abort prog giving 7 flashes.
    Anyone got experience of these bundles of joy?
    Checked for motor issues, nothing obvious to see.
    Thanks,
    Eddie.
    #358144
    Re: Haus WM1050w 7 flashes.
    Have you got a photo of it?
    If we can figure out where it came from,who made it, then the fault codes are probably already known.
    gandh1
    http://www.youtube.com/watch?v=HdtvDIww4_o here you go ken….
    looks like a chinese rip off of a beko, so… haier??
    #358146
    Looks like a Midea machine made in China, sorry made in PRC. 😉
    Should be similar to the Zanussi and Amica etc. clones that are about.
    bazza500
    It’s made by Haeir. 7 flashes is a motor fault. Usually toc in motor open circuit. If you have the serial number I can send you the manual.
    #358148
    gandh1
    so “hec” is haier electrical co.?
    #358149
    Madmac
    Thanks for quick replies guys. Checked motor for continuity and leakage.
    Might be worth checking motor relay on PCB and wiring between the two, the wiring seemed particularly unsupported I noticed.
    I think these machines are pushed by that retailer of quality….Argos :rolls:
    Thanks,
    Eddie.
