Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Have I broken my dishwasher door?
- This topic has 9 replies, 4 voices, and was last updated 9 years, 2 months ago by
mumtofiveboys.
January 27, 2017 at 10:31 am #90450
mumtofiveboys
ParticipantI wanted to see inside my dishwasher whilst it was on to see if I could identify a leak…
I have seen engineers do this by putting something in the door latch when open and turning the machine on. I did this and it worked but I am now unable to shut the door, it closes but is not engaged and just pulls open again.
Is this something that can easily be repaired or requires an engineer?
Am I now looking to buy a replacement dishwasher 😕
Advice gratefully received!January 27, 2017 at 11:00 am #444840kwatt
KeymasterRe: Have I broken my dishwasher door?
A make and model would help… 😉
But normally if you look at where the catch snaps in there’s a latch, it’ll need flicked over to the open position, it’ll be in the closed one and that’ll be why you can’t shut the door.
But doing that, running the DW when the door’s open, not a good idea at all.
January 27, 2017 at 11:20 am #444841timdowning
ParticipantRe: Have I broken my dishwasher door?
You won’t find a leak that way anyhow as there will be water spraying about…
You’ll just end up getting wet.January 27, 2017 at 12:33 pm #444842mumtofiveboys
Thanks for your feedback. Sometimes a little knowledge is a bad thing and I should leave the technical stuff to the professionals!
It is a Miele G1270 SCVIJanuary 27, 2017 at 12:39 pm #444843mumtofiveboys
January 27, 2017 at 12:49 pm #444844kwatt
See that little plastic thing right in the middle, that’s the wrong way I’d imagine but there’s zero tech support on Miele (they don’t play nice with others) so I can’t tell you much else.
January 27, 2017 at 1:50 pm #444845mumtofiveboys
Thanks Kwatt, maybe someone has a picture of their door to compare?
January 27, 2017 at 4:11 pm #444846timdowning
It’s simple don’t overthink it.
Get someone to take the door apart to flick the catch back into the correct position.
No tech info or photos required!January 27, 2017 at 4:15 pm #444847Martin
You don’t need to “take the door apart”. Just place a loop of stiff wire to hook under the catch and pull upwards…..simples.
January 27, 2017 at 5:06 pm #444848timdowning
I didn’t want to suggest that Martin due to poking a wire into a potentially live area (I know we tell them to unplug appliances) & if they pull it incorrectly the cost of a new lock…
The leak needs to be looked into too…
