have i diagnosed this problem right?.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries have i diagnosed this problem right?.
  • #48490
    TELL
    creda TCR14 starts to run for approx 5/10 mins, cuts out, press start button about 10 mins +. then starts up again. keeps on running like that.
    have checked the stats at the heater(which is only for the elements) and the stat for inside the drum (front/ top). had the float switch checked ok. condenser/ container all clean.
    put fault to relay cutting out?.
    or is there something i’ve missed out on checking. thanks
    TELL..
    #296736
    Re: have i diagnosed this problem right?.
    It’s the Relay (Part No C00095530) behind the control panel needs changing Tell.
    #296737
    TELL
    thanks martin. just double checking
    TELL..
