this comes up for bosch
[h=3]Bosch oven error code E011[/h] When your Bosch oven keeps showing E011 error code this indicates a button has been held down for too long. Or has jammed. If the main oven performs perfectly on its own but Bosch oven error code E011 is displayed when the grill door is open and the grill is switched on this points to the main oven control failing. And you’ll need to obtain a new control board.
Hi Dave,
Thanks for that, the only problem there is that we changed the main P.C.B. two months ago as it had an earth fault. I will have to investigate this further.
