HDW1011WG (857008415101) has stopped heating the cold water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HDW1011WG (857008415101) has stopped heating the cold water
  • #83568
    chalky2109
    My HDW1011WG (857008415101) has stopped heating the cold water feed coming into the washing machine (showing no fault code that I can see), Can anyone advise if there’s a test program I can run to see if there’s a fault.
    Can anyone advise what might be the cause of the fault?
    #423127
    Re: HDW1011WG (857008415101) has stopped heating the cold wa
    are you certain dont know with this machine but if the door is double glazed its hard to tell and since rinses are cold you cant tell at the end
    try a very hot wash to be certain
    dont know with this machine but a lot of machine skip heater cycle without error code if not heat is detected. so its worth checking heater. also some whirlpool machine wont atart if heater is broken
    still the first thing i would check once you are certain its not heating
