Heater dishwasher hot point Aquarius model FDW70p
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Heater dishwasher hot point Aquarius model FDW70p
  • #83337
    Sarahplant
    The wires that go in to the terminal on the heater have broken off as they are burned. Do you supply these? I need a female connector. Also I have found difficulty in disconnecting the hoses on to the heater. I need some new metal clips that clamp the hoses on to the heater at either end. Also how do you refit the metal clamp back over the hose? What do you suggest?
    #422477
    Re: Heater dishwasher hot point Aquarius model FDW70p
    Don’t think the connector block is available as a spare part. Usually cut off as close as possible and replace with seperate, insulated AMP tags. The chances are that if repaired they will soon burn out again and replacing the heater assy is the only certain cure……..Until the pcb fails that is. :rolls:
    As for the clips i dont try to refit them, lifes too short to faff around with such poor clips. I replace them with thin jubilee clips of the same size.
