Heater element
  • #92542
    Russellransome
    Hello,
    I have a proaction dishwasher from Argos which has no service back up at all.
    I believe the heater element has gone but nobody can find one for this model. I have looked at mine and it’s a 32mm 1800w flow through element, my question is can I replace it with a different make element aslong as it has all the same connectors and all the same specifications?
    Thanks Russell
    #451543
    1totalshambles
    Re: Heater element
    As far as known yes as I`d be inclined to fit a Beko 1800w element which should be the cheapest option followed by one of the Zanussi ones but beware some of those are a different tube diameter and are more expensive anyway.
    If you live in a hard water area make sure that you are using salt and do not rely on 3in1 or such like tablets alone. Cylindrical heater failure is fairly common right across the board mind you Bosch heat pump failure is even worse, shocking rubbish.
