Re: heater element continuity testing results
Thank you for help. Would like to have known why my multi meter produced results of continuous breaks in continuity with these elements. Good news is that due to your response Dave, I refitted the element, replaced carbon brushes that I had swapped around nearly a year ago when the drum would not turn. Had already cleaned main board and other areas of carbon dust just in case it could cause electrical issues. I assume it could still conduct electricity. The machine is doing a wash load as I type with element working and no error codes. In future this and what you have said Bazza500, resistance and not continuity will be the test. Thanks.
