Heating element for zwf12170w Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Heating element for zwf12170w This topic has 1 reply, 2 voices, and was last updated 11 years, 7 months ago by neilsukwg. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts September 9, 2014 at 3:40 pm #82167 neilsukwgParticipant I have in stock a heating element 1325347100 1950w and need according to qualtex online a 1325064234 also 1950w (not in stock) Are they likely to be compatible? I will use the original ntc The machine runs the pump for a short while then goes to end The existing element is legal but the insulation is way down so i hope a new one will sort it out The only fault code retained is 43 September 9, 2014 at 4:35 pm #418978 MartinParticipant Re: Heating element for zwf12170w The compression gasket differs between the two so don’t fit the one you have as chances are it will pop out like a willy out of Y fronts. 😉 E43 = Door interlock blown triac on the PCB. 🙁 Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
