heatrae water boiler
Home Forums General Trade Forum heatrae water boiler
  • #12285
    streetlighter
    Hi all
    Does any one have any info on a heatrae sadia supreme 140 water heater.
    I have one in my sons lower school which is poping the the top cut out which you can reset.
    Works again for a few times them it trips of again 🙁 thought I had fixed it 😳
    What are the 2 rod type things in the right hand side at the top which both read open circuit. ❓
    Ta for any help or any info where I can get a manual for this as they are nearly £600.00 to buy. 😯
    Paul
    #148884
    Re: heatrae water boiler
    streetlighter wrote:What are the 2 rod type things in the right hand side at the top which both read open circuit. ❓ l
    The Solenoid Valve? :con:
    Parts Center list a couple of variants to fit that beast (D71038 & D71031)
    #148885
    Seamy
    http://www.heatraesadia.com/hs/heatraes.nsf
    check out hear there is some helpful advise on there & details of how to get parts etc, i’ve had a few problems with their boilers before but nothing a set of thermistors wouldn’t cure, if the button needs to be reset it means that the control thermistor or control thermostat is not functioning properly, BOTH thermostats have to be changed, High limit cut-out & control one, from memory, best of luck..
    #148886
    streetlighter
    Hi martin
    It does refill when you drain a cup out but it does seem farily slow to do it. The prob is I cant tell how fast it needs to fill.
    Tryed to test when c/o trips but could’t tell if it had finished filling may have to make a return call to check this theory out.
    Ta
    Paul
