HEC 1050S MODULE FAULT
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts HEC 1050S MODULE FAULT
  • #53354
    DAR01
    I’m trying to source a module for the above any ideas anyone, i’ve been in touch with Argos spares and they don’t have the part listed.
    Does anyone have a similar scrap board as i may be able to repair the original board using donor parts.
    The electronic switch (ACS1086S) which switches power to the outlet pump is damaged due to a fault on the pump.
    Does anyone know of an equivalent (ACS1086S)as i don’t seem to be able to source this part in the UK.
    Mike
    #315504
    bazza500
    Re: HEC 1050S MODULE FAULT
    JTM do spares for HEC
    #315505
    RS
    37p each but you’ve got to buy ten. Nextday delivery by DHL though included in price. (You might need to open an account but it’s straightforward and fast.)
    Mike.
    #315506
    DAR01
    Thanks leavemetogetonwithit but unfortuneately the type RS stock is the Surface Mounted Type the one i need looks like a transister and has 3 legs
    out G and com. TO-92 TYPE.
    Mike
    #315507
    If you click on the link below the product for the PDF data sheet, it will show you a picture of the smd next to the TO92 version. You could just solder the appropriate legs to the legs of the old one.
    8)
    Mike.
    #315508
    DAR01
    Never thought of that i will order some and try your suggestion, thanks.
    Mike
    #315509
    Make sure to have the data sheet drawing next to you while you’re working as you’ll need to cross your legs!
    Mike.
