HEC 12ESM Dishwasher
  • #54413
    Hollytree_Technical
    Hi all
    Does anyone know which machine this is a clone of or even more specifically what fill valve it uses – been told that its not filling so suspect valve but would like to take one with me when I go to see it.
    Thank you in advance.
    Jeremy
    #319511
    Re: HEC 12ESM Dishwasher
    HEC = Hong Kong Electric Company = Haier/Midea. Personally, I’d refuse the job. I do have some standards to maintain.
    Hollytree_Technical
    That bad are they? – perhaps that is why I can’t even find mention of them on connect.
    Unfortunately as I am still in my first year I can’t afford to be too picky about what I take on.
    Jeremy
    #319513
    pup
    could be float s//w
    #319514
    Chinese dishwashers have known ploblem with connection to water flow meter (reed switch thing sticking into side of metering tank behind left hand side panel.)
    Mike.
    #319515
    Flow meter failure won’t stop it filling. It might time out or it might flood. Inlet valve is most likely culprit. Think 10 year old Indesit – it’s the same machine, just worse; so you need a single coil, straight through valve if you really feel that you have to fix it.
